Identifaction
Old Jan 28, 2005 | 11:32 AM
80`F-150's Avatar
80`F-150
Identifaction
I was wondering what the easiest was to identfy a tranny and gears in my rear end.One tranny is from the 460/429/400/351 class and the other is 302/351W class and help is appreciated.
Old Jan 28, 2005 | 10:29 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Well, the easiest way to identify the tranny would be to post up some details about it...
What kind and year of vehicle did it come from?
What engine was it attatched to?
Is it an auto or manual?
How many gears does it have?
If it is a manual, is the first gear a 'granny'/'creeper' or a regular first gear ratio?
If it's a manual, are all the gears synchronized or just 2nd on up?
Is high gear an overdrive or is it direct 1:1?
Is the case aluminum or iron?
Does it have a one-piece case and bellhousing or a seperate bellhousing?
If it is an auto, how many bolts does it have around the pan?
If it's a manual, where does the shifter come out at, top, side, rear?
Does it have a PTO access plate on it? If so, what side?
Are there any distinguishing markings on the tranny?
What is the shift pattern?
On the axle gears, look on the axle's differential cover for an information tag attatched to one of the cover bolts. The ratio will be listed there. If it doesn't have a tag, look for an axle code on the driver's door VIN/weight sticker. Post it and we will try to decode it for you. Any extra info you can give about the axle will help us identify it...
What kind of truck did it come from? What year?
Is it a full-floater or a semi-floater?
How many lugs does it have?
What is the GVWR of the truck it came from?
Does it have a bolt-on rear cover (Dana or Ford/Sterling/Visteon) or is the rear cover welded on and a removeable 3rd member housing attatched to the front of it (9" Ford)?
If it has a cover, how many bolts are around it?
Does the cover have a fill plug in it or is the fill plug in the axle housing? What shape is the cover?
Post up as many details as you can and we will try to help the best we can .
Old Jan 29, 2005 | 07:50 AM
80`F-150's Avatar
80`F-150
It came out of a 1981 F-150.
It was on a 351M.
It is an auto.
3 forward gears.
The case is cast
I will have to check on the number of bolts around the pan.
and for the rear end i do think the tag is on it i`ll check on that to and if its not there i`ll post again
Old Jan 29, 2005 | 11:26 PM
SoCalDesertRider
The trans is probably a C6. It should have 17 bolts around the pan, one-piece aluminum case/bellhousing and the shift pattern P-R-N-D-2-1.
Old Jan 30, 2005 | 02:58 PM
80`F-150's Avatar
80`F-150
It does have 17 bolts around the pan.So that means it is a c6?whats the gear ratios in it?thank you for the help
Old Jan 30, 2005 | 07:54 PM
SoCalDesertRider
Yes, it should be a C6.
C6 ratios are: 2.46, 1.46, 1.00, rev- 2.18.
