Electrical or Mechanical???
Old Jun 18, 2002 | 02:45 PM
chief_ret2001's Avatar
chief_ret2001
I own a 1986 F-150 302motor. I have replaced the battery, starter,
alternator and battery cables. Works fine until I use the air conditioner. Running the air con will drain the battery. ANY SUGGESSTIONS on what's wrong????
Old Jun 18, 2002 | 04:45 PM
angus's Avatar
angus
Does the truck have a voltmeter or ammeter?
Wild guess: a belt slips when the a/c compressor engages, so the alternator doesn't charge (I'd expect this to be accompanied by a lot of squealing).
Old Jun 18, 2002 | 09:48 PM
chief_ret2001
truck has am ammeter...had it cheched and the charging system is working ok. no squealing sound as all belts are tight. if i dont use the a/c, it works fine all the time. only when i use the a/c for a while and then turn off the motor it will not start again unless with jumper cables or if i charge the battery.,,,,,,help......
Old Jun 20, 2002 | 07:35 PM
kspilkinton's Avatar
kspilkinton
My guess would be that you have a hot wire in your a/c system that's shorted to ground with a large current draw. This should trigger a fuse to blow unless the fuse block is shorted or wired directly to the battery.
When the switch is placed in a/c you have a few more connections that become electrically hot, and things that cycle between on and off. I'd check the wiring harness to your a/c for any grounds that don't belong there. Most of your factory ground wires will be all or mostly black.
Lastly does the a/c actually work? Are you getting cold air? If so then it's probably not a mechanical problem.
-Kerry
Old Jun 20, 2002 | 07:47 PM
DannyP's Avatar
DannyP
I would suggest disconnecting the wire to the AC clutch and turning on the AC on your controls. Run it this way for awhile to see if it still drains your battery. If it doesn't then it is pretty much a sure bet that you have a short in your AC clutch. If it still drains then you have ruled out the clutch.
DannyP
Old Jun 20, 2002 | 09:16 PM
brown 4x4's Avatar
brown 4x4
