Carb Guru's need help???
Old Jan 27, 2005 | 08:27 PM
jd_sylvia's Avatar
jd_sylvia
Question Carb Guru's need help???
I am trying to find out what I have. It is a Motorcraft 4 barrel the numbers on the base plate are as follows
C1AE AH
Size and what it came from would be helpful.
jd
Old Jan 28, 2005 | 02:08 AM
captcarstop's Avatar
captcarstop
C1 = 1961
A = full size car
cant help on the rest.
there should be some other numbers on it some where. those will probally do you better in your search. I usually just take all the numbers I find and rund them through Google and see what pops up, get what I need that way 90% of the time.
Ron
Old Jan 28, 2005 | 06:09 AM
barry's Avatar
barry
It's from a 61 Ford car or Tbird( used on both) with a 390 w/Cruise-o-matic tranny.
Barry
Old Jan 28, 2005 | 09:30 AM
Mike G's Avatar
Mike G
Just a guess but probably in the 500-600cfm range.
--Mike
Old Jan 28, 2005 | 07:54 PM
jd_sylvia's Avatar
jd_sylvia
Thanks Gentlemen.
I will search for more numbers.
I thought it had a tag on it when I rebuilt it but didn't see it when I took the carb off this time.
Again Thanks gentlmen
jd
Old Jan 28, 2005 | 08:17 PM
barry's Avatar
barry
The C1AE-AH is the tag number. It's all you will find on a Ford carb. That's what we use to look up carb parts. The Ford parts & acessories catalog states it's a Ford 4 barrell carb or a "shoebox carb" as they're also called. What I listed above is what it fits, right from the parts book.
Barry
Old Jan 29, 2005 | 08:26 PM
jd_sylvia's Avatar
jd_sylvia
Thanks alot Berry
I think I might put it on ebay. Saw some yahoo at the swap meet trying to sell one for $100.00..
I think I'll see what it raises.
JD
Old Jan 29, 2005 | 08:50 PM
barry's Avatar
barry
THey are getting scarce, especially rebuildable ones. I've seen them go in that area of $100 . Easy carb to do, simpler than a Holley and not as fussy! I used to do them in my sleep in the early 70's when they were a dime a dozen.
Barry
Old Jan 30, 2005 | 10:55 AM
jd_sylvia's Avatar
jd_sylvia
Thanks Barry
I have rebuilt alot of Holley carbs and I have rebuilt this Motorcraft once. I was brought up around Holley carbs so they seem to go easy. one of the features I like about the Holley is the easy float adjustment. I could never get the Motorcraft from running rich always had a black exhaust pipe. Now I probably could have spent some time with it and got it right but like I said Holley carbs come easy to me.
Thanks again Barry
Old Jan 30, 2005 | 01:48 PM
barry's Avatar
barry
I guess it's all in what we've worked with. I always stayed with Ford carbs as I had acess (parts manager) to any parts I needed for my projects.
Barry
Old Jan 30, 2005 | 05:42 PM
jd_sylvia's Avatar
jd_sylvia
I probably would have kept it on if my older brother still worked for Ford. He was their top computer guy at a dealership in Lodi CA. He is also the best auto mechanic I have ever known. He opened his own shop way up north and it is just to far to drive for a rebuild.
Anyhow here I go again blahblahblah.
Thanks again Barry
