Oil & Lubrication
Changing gear oils
Old Jan 27, 2005 | 08:09 PM
EXPLORER9150's Avatar
EXPLORER9150
Changing gear oils
I have 00 exp 5.0 AWD And need to change gear oils in frt and rear diffs. and also tranfer case.Is it best to use Ford Part numbers or aftermarket gear oil. ,,,Thanks
Old Jan 27, 2005 | 09:35 PM
aurgathor's Avatar
aurgathor
If it's under warranty I'd use Ford oils. Otherwise whatever synthetic I have in the appropriate weight.
Old Jan 28, 2005 | 12:46 AM
99F150's Avatar
99F150
Ford is using syn. gear oil now in the differentials M1 75w90 and I believe the transfercase calls for atf. The Ford part for that should be Mercon
Dan
