1979 F250 electrical problems
Old Jan 27, 2005 | 05:47 PM
jacksprat's Avatar
jacksprat
79 F250 NO electric anywhere
Old Jan 27, 2005 | 05:57 PM
kc5hwb's Avatar
kc5hwb
A little more info is needed...
Electrical in the motor/cab/ both?
Do you have a battery? Is it charged? Is it grounded?
Where are the battery cables running to?
Where are the cables from the solenoid connected to?
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
Well it probably is the fusible link in the harness but,you may want to give out some more information regarding what you have checked.
So we know where to start
We don't have a Karnac on this site
Old Jan 27, 2005 | 06:13 PM
jacksprat's Avatar
jacksprat
Okay, more info...here we go. The truck was running normally, for the most part. The lights on the plow went out. The main lights worked and then the wipers started to double time the volume on the radio went to 10 and then the engine started missing (for about 10-15 seconds) and then everything went out. EVERYTHING . I have 2 new battaries and all of my fuses are good. I did smell the electrical burn briefly but did not see any smoke. Is there something under the dash that i can check or under the hood? I jumped the sol and the engine cranked but did not push it any farther.
Old Jan 27, 2005 | 07:48 PM
kc5hwb's Avatar
kc5hwb
When you jumped the solenoid and the negine cranked, did your lights still not work? Was it trying to crank without anything else working? If so, the solenoid may be bad. The battery hooks to the solenoid, then to the rest of the truck. If that goes out, everything dies.
Old Jan 27, 2005 | 07:55 PM
jacksprat's Avatar
jacksprat
Thanks KC . I did not check the lights, but I will. also going to change the sol just for gp. Would that have effected the voltage reg also?
Old Jan 27, 2005 | 10:11 PM
Franklin2's Avatar
Franklin2
This is only partially correct. The battery does hook to the starter relay(solenoid), but the starter relay(solenoid)'s job is to supply current to the starter. If it went bad, it would only keep the starter from working, not the whole truck.
But it is a connection point that powers the whole truck. In the diagram below, point #3 has a smaller wire connected to it. This is the one that powers the whole truck. Follow it down a little bit, and you may see a small rubber thing in the wire. This is a fusible link, and it may be burned out. Keep following the wire, and you may find more wires with fusible links in them.
If you get it going, carefully measure the voltage at the battery, and try not to rev the engine. If it is way over 16 volts, you need to check the wiring around the alternator and the regulator.
If the truck has power, but won't fire, the high voltage spike you experienced may have burned out the ignition module.
