Overdrive "OFF" Light Blinking?????
Old Jan 27, 2005 | 04:54 PM
Peterson's Avatar
Peterson
Unhappy Overdrive "OFF" Light Blinking?????
My Overdrive "OFF" light is blinking. The overdrive will still turn off, but the light keeps blinking. Any ideas??
Old Jan 27, 2005 | 05:18 PM
High_Horse's Avatar
High_Horse
Its a code for your transmission electronics, torque converter lockup, shift controls etc...you need to get a scan done to pull the code.
Old Jan 28, 2005 | 07:33 PM
Lauda's Avatar
Lauda
I had the same problem with my old E-350. Try this:
Remove one of the battery cables for 5 minutes ore more. Then connect it back, start the engine, drive the car nice and easy up to O/D, drive in O/D for 2 minutes ore more before you stop the car. Turn of the ignition. When you start next time, will hopefully the O/D light be turned-off.
This procedure helps me for a couple of days, and then the problem went back. If this happen again take the car to a dealer for error code reading.
Old Jan 28, 2005 | 11:15 PM
High_Horse's Avatar
High_Horse
All that does is get rid of the blinking O/D light, it doesn't remove the code or problem. I had to have my torque converter replaced on mine. I highly recommend you get that code checked.
Old Jan 29, 2005 | 05:09 AM
trike1946's Avatar
trike1946
Get it checked. The longer you wait the more it is going to cost to fix it.
