Temp gauge
Old Jan 27, 2005 | 06:05 AM
hiway's Avatar
hiway
Temp gauge
Hello,
Hope someone can help. '90 F-150 w/300 six. Temp gauge quit working. All other gauges fine. Can anyone tell me where the sending unit is? Dealer couldn't tell me.
Thanks,
Paul
Old Jan 27, 2005 | 09:22 AM
mudinford's Avatar
mudinford
I have the same issue....i did a rebuild and installe the motor 5 years later! Is the sending unit in the upper rad neck? OR in the block? Haynes says nothing on locations. Thanks! Mines an '86.
Old Jan 27, 2005 | 09:28 AM
yttrium_on_rye's Avatar
yttrium_on_rye
In my 77 300 the sending unit is on the passenger side in the back above the starter. A real convenient place Ford put it in!!!!
Old Jan 27, 2005 | 03:07 PM
cjbronco's Avatar
cjbronco
I have the same problem. A guy at the garage didn't know, but I've heard that its on the RH side lower block. Its jsut been way to cold to try and climb under there and connect it. But I would love to know of a definite spot.
Old Jan 29, 2005 | 07:32 AM
Gasurffish's Avatar
Gasurffish
On a 96 the sender is located on passengers side of block towards fire wall can be gotten to by looking up wheel well . Has one wire connection. It is up high on the block
Old Feb 3, 2005 | 06:25 AM
hiway's Avatar
hiway
Hello finally!
Finally had the chance to crawl under it. You guys were right. The sender is directly above the starter, high up on the block. Pulled the wire off and put a test light in the terminal and with key on got a dim light. At the same time the gauge started to move to the hot side. I feel pretty certain a sender will cure this problem. (already bought one) I think I'll remove the starter before changing it tho. Don't want get antifreeze in it.
Thanks for your help.
Paul
thejean
6.7L Power Stroke Diesel
Aug 12, 2011 02:59 PM
2funride
Jul 16, 2009 01:34 PM
paul2112
Jul 20, 2007 09:11 PM
dotty
Feb 26, 2003 10:41 PM
