OD light flashing
Old Jan 27, 2005 | 05:16 AM
mattskn's Avatar
mattskn
OD light flashing
the light on my shift that tells you if the OD is on or off started flashing on my 95 f150 2wd the outher day after I did a fluid,filter change never had the problem in the past . trans seem to be operating properly and fluid are full any ideas what it couldbe .
Old Jan 27, 2005 | 05:38 AM
BSHORT's Avatar
BSHORT
Top Answer: 5
Look For A Code. The Flashing Light Is The Transmissions "check Engine" Light.
Old Jan 27, 2005 | 03:30 PM
cmoore99's Avatar
cmoore99
I had that problem once on a front wheel drive Windstar. The OD light started flashing and I kept on going. About 25 minutes later the whole transmission went up in smoke. One god awful smell. I would have that checked out pronto.
