1978 - 1996 Big Bronco
Back Window on 1986 bronco
Old Jan 26, 2005 | 11:05 PM
bluebronco86's Avatar
bluebronco86
The rear window of my bronco will not go down, please help!!! Also, i'm looking for some aggresive sounding pipes.....any suggestions?
Old Jan 27, 2005 | 06:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly...to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..
See you on the boards.
Old Jan 27, 2005 | 08:48 AM
cje07's Avatar
cje07
Could be a number of different things.
1) First have you tried using the key in the tailgate to get it down as well as the switch in the cab?
2) If you use the switch in the cab...can you tell if there is a load to the system (the clock lights should dim, voltage should drop slightly)? If so then the switch works but the motor could have screwed up a gear.
3) Is the tailgate totaly shut? Go back there and give it a good push. Then try the switch/key.
4) If the switch does not work, the key does not work and the push method does not work...get inside the vehicle, take the back panel off from the tailgate to get access to the motor. You can use a battery charger to reverse the polarity on the motor (shoudl have a + and - lead to the motor)to see if you can get it down. If the motor works and the window goes down, then you may have a bad wire located where the wiring leads into the tailgate from the side fender (left-hand lower side of the tailgate) This happened to my 86 last time and has happened again...I need to take the time to fix it again.
5) If the motor is bad (gears) you can pick one up new (dealer) or used from the boneyard. Do a search on this site...there are many vehicles you can get a motor from...broncos, F-150, Crown Vics etc...I think the driver side door motors from these vehicles will work on the tailgate...they are compatible
Others will have suggestions to try as well...or can clarify what I have said. Good luck! Let me know what it was.
Old Feb 6, 2005 | 12:22 PM
bluebronco86
I got out there and took off the back panel of the tailgate and looked around a little bit. When i tested the motor and wires, they all worked fine. So, i checked the fuses and it ended up being a bad fuse. I replaced it and it works fine now!!
Thanks!!!
