please help rear rotor removal
Old Jan 26, 2005 | 07:25 PM
tonytone's Avatar
tonytone
hello, i need help removing rear rotors, 98 4x4 navi
thanks
Old Jan 26, 2005 | 07:51 PM
the4by4freek's Avatar
the4by4freek
Remove the caliper, caliper bracket. Then back off the parking brakes with the wheel adjuster in the rear of the rotor plate. There will be a little rubber seal that is oval shaped on the backer plate, the adjuster is behind this. The rotor should then just slide right off. In some cases after you have the caliper and bracket off, the rotor will just slide right off. Be prepared.... the calpier bracket is extremely tight! Use impact if possible.
Old Jan 26, 2005 | 08:45 PM
tonytone's Avatar
tonytone
as i left work today i noticed a little pull but i thought it was just snow so i kept going 3 minutes later i felt a vibration and a sound as if i was dragging some type of metal'ish object.. stopped looked all over and nothing... started to move and the same thing happend.... something inside the rotor broke and thats whats grinding.....I need to take the rotor off to clear everything out.. im guessing that WAS the e-brake assembly right? ohh did i say that the e-barke peddle was half way down......... im guessing I would have to buy the whole thing right? can you guys reply and give me some input..
thanks
Old Jan 27, 2005 | 01:51 PM
the4by4freek
Tony, the E-brake is set up just like a drum brake setup on rear drum brakes. You can buy individual parts for this. There are 2 shoes and an adjustment wheel( tensioner) and a few other pieces in there. It definately sounds like you got a problem! Either way, the rotor removal will be the same. Make sure you hang your caliper by a metal wire so it's not hanging by the hose.
Old Jan 27, 2005 | 06:43 PM
tonytone's Avatar
tonytone
WOW, I tryed everything after taking off the caliper. wd-40 hit with hammer all over tryed for a good 3 hours and had no luck removing that rotor.. i just wanted to avoid the mechanic all together.. any one alse have any advice?
thanks your help is all i have.
Old Jan 28, 2005 | 02:29 PM
the4by4freek
Get a BIGGER hammer! You might need to break the rotor to get it off. If you got broken peices in the E-brake assembly then you're definately gonna have a time! If you can't break it in half with a hammer try a torch!
Old Feb 1, 2005 | 08:04 AM
hceptj's Avatar
hceptj
Exactly. Pick up a new one at your parts store and then stop by Home Depot, Lowes, etc. and buy a sledge. They will come off but will be warped or broken by the time your done.
Remember to antiseize the new one...
