Alt. Light
Old Jan 26, 2005 | 05:21 PM
minishtr's Avatar
minishtr
Question Alt. Light
I have a weird problem with my 66 F100.With my engine running I have a feint alt light but,I have 14.4 volts at the battery.Any hints what it is?
Brian
Old Jan 26, 2005 | 05:58 PM
jtmerritt's Avatar
jtmerritt
Could be a bad ground or corrosion on some connectors causing high resistance. Clean all connections and coat them with dielectric grease to help prevent corrosion.
John
Old Jan 26, 2005 | 09:16 PM
Franklin2's Avatar
Franklin2
Especially check at the regulator. Clean the spot where it bolts to the sheetmetal and clean the plug terminals.
