Sponsored by: Auxito
blinker & flasher problem
Old Jan 25, 2005 | 09:23 PM
gunar's Avatar
gunar
i have a new to me 97 f-150 4.2l. sometimes the blinker does not work & just makes a buzzing noise. when i retry it it usually starts working. when i try the emergency flashers sometimes just the right side works.do you guys think i can take the steering column apart & clean the switches to fix this problem or are new parts required?
Old Jan 26, 2005 | 05:13 AM
gfreek's Avatar
gfreek
Possibly the Multifunction switch, which is the turnsignal switch, and or the flasher relay. I have changed both on my 99. The relay at least 3 times, dealer warrantied it once, new defective part, only afew months old. Multifunction switch can do strange things when it goes bad.
Old Jan 26, 2005 | 07:03 AM
RoyalFord's Avatar
RoyalFord
It makes a buzzing sound? Can you hear the relay clicking?
Old Jan 26, 2005 | 07:16 AM
Wizardvette's Avatar
Wizardvette
In the cold weather, my blinker acts up. It comes on, I can hear it clicking faster than it should, no arrow on the dash. After temps in the cab warm up a bit it seems fine. I guessed this was just a flasher module, and planned to replace it this weekend.
Old Jan 26, 2005 | 06:59 PM
gunar's Avatar
gunar
no. just a buzzing sound till i wiggle the blinker lever.
Old Jan 29, 2005 | 09:21 AM
mathelm's Avatar
mathelm
The Buzzing sound is the same thing that happens if both (front n back) lights are out. Sounds like a bad conection or contact somewhere.
