removing shifter
Old Jul 15, 2002 | 07:54 PM
85f150s6_4x4's Avatar
85f150s6_4x4
removing shifter
i am trying to figure out how to remove the shifter i have an 85 f150
i6 and am having tranny trouble acts like it is not going in gear any help would be great thanks
Old Jul 15, 2002 | 08:07 PM
topo4u2's Avatar
topo4u2
removing shifter
I think I will need to know if it is an automatic or standard?
Old Jul 16, 2002 | 09:25 PM
85f150s6_4x4
removing shifter
it is a standard trans. reg cab 8' bed any ideas
Old Jul 16, 2002 | 10:06 PM
97 XLT's Avatar
97 XLT
removing shifter
If you have a mat or carpet you will have to pull it back and on the tranny tunnel remove the screws that hold the shift boot to the floor under that is the tranny remove the bolts holding the shifter flange to the tranny then lift the shifter out.
Old Jul 17, 2002 | 06:07 PM
82F100SWB's Avatar
82F100SWB
removing shifter
97F150: that only applies to a M5OD, most of the older 4 speeds have a screw or lock setup on the shifter itself.
Evan MacDonald
1982 F100 SWB
300 HD: Cliffy 290H, 9.1:1 compression, forged everything, ARP'd bottom end/Hedman hedder/dual 2½" exhaust
NP 435/2.75 geared 9"
1986 F150 HD, 300 HD/needs a NP 435/4.10 geared 8.8
70,000 miles
1984 F150 XLT Lariat parts donor, 351W/C6/9" LOADED to the hilt, 201,000 miles
1980 F100 Custom, 300/Np 435/2.75, 58,000 miles
Old Jul 17, 2002 | 08:37 PM
topo4u2's Avatar
topo4u2
removing shifter
On some of the Fords you have to twist the top nylon screw housing off to get the shifter out..it is a bit tricky but should be ok.
Old Jul 17, 2002 | 09:05 PM
model t's Avatar
model t
removing shifter
