Missing bad very loud
Old Jan 25, 2005 | 05:41 PM
96gizmo's Avatar
96gizmo
Trailering
I have a 96 powerstroke that has 118000 miles and just started missing and very loud engine. It starts just fine in the morning when is is cold, temp here is about 30 degrees in the morning. I start it up and it sounds great for the first minute or so then the porblem starts and the check engine light comes on. I let it run for a while and it will calm down and idle normally and the light will go out.I stopped at autozone today and had them check for codes and there were none. Just gave a pass code. Anyone have any suggestions?
Old Jan 25, 2005 | 06:04 PM
ltfox's Avatar
ltfox
I would find another place to get your codes pulled. If it gave you CEL then there should be a code. Sometimes different code reader can read things other can't.
Old Jan 25, 2005 | 06:10 PM
KC0FHM's Avatar
KC0FHM
couple things, it should have a code after a check engine light appears.
Could anyone have put gasoline or the wrong kind or amount of additive in the tank?
Ron
Old Jan 25, 2005 | 09:21 PM
96gizmo's Avatar
96gizmo
Trailering
I am the only driver so I dont think anything but diesel fuel has been used but the last tank I got from flying J had a lot of water in it. I had to change the fuel filter yesterday and it was still giving me an intermittant water in fuel light today.
Old Jan 25, 2005 | 11:00 PM
1997F-350's Avatar
1997F-350
go to advance to get your codes pulled. autozone uses an el cheapo scanner. my personal experience(autozone getting codes read = nothing 10 minutes later at advance 2 codes found. oh and the water sounds like your problem. dont drive to long with you water in fuel light on. my dad did and lost 3 injectors this way. hope that is not your case. good luck.
