Transefer Case
Old Jan 25, 2005 | 04:39 PM
BIG PAT's Avatar
BIG PAT
Transefer Case
Hey
I am converting my truck to 4wd. It is a 1985 f150. I belive the trany is a t-18. it is a 4 speed with a granny gear and the door code is A. I would like to know what transrer cases will bolt up to it. I relize sinse it currently just has a tailshaft that i will need to Probably change the output shaft.
thanks alot
Old Jan 25, 2005 | 09:12 PM
justshootme84's Avatar
justshootme84
t-case options for that year range (mid-80's) were the New Process 208 and Borg-Warner 13-45. I also think a B-W 13-56 may bolt up to your tranny. The shifter linkage is different for each model, so get that too with the donor case if possible.
Old Jan 25, 2005 | 10:26 PM
mustange70's Avatar
mustange70
Any transfer case from the mid 70's up to 96 ford 1/2 tons and up to 97 3/4-1 tons will work, as all the tailhousings/t-case's (execpt the divorced mounted np-205) all have the same inputs, but like justshootme said, be sure to grab the shifter as well. If you can try to find a NP-205 t-case as those are nearly built proof and is something a stock truck shouldn't break, but to use one of those you need a tranny crossmember (it has a drop in it so as to clear the d-shaft), and a bracket need to be made for the side mount on the t-case, also what ever t-case you get be sure to grab the adapter that mounts it to the tranny, as this will save you many headaches (assuming its a NV-435, which is easy to tell as they have tags, same with the t-case). Hers a picture of that additional bracket you would need to make (and what the crossmember looks like to, i will be putting 2 more bolts on the bottom of the frame for extra support too)
