torque converter or transmision?
Hello friends
ongoing problems still persist.
Sometimes the truck has no problems shifting then other times it has a hard time going into second, have to take foot off the gas for it to shift. and also sometimes it will not go into overdrive, just stays in next to last gear. Other days no problems at all. wondering how to tell the differance on torque converter problems compaired to transmision problems.
thanks
02 f250 4 X 4 automatic, CC
115000 miles
Michael
thanks
115000 miles
Michael
train460,
Boy, I got to feel'n sorry for ya. Not one post to your thread all day! Well, to the rescue I come! Not with an anwser to your problem however (sorry), just a suggestion:
Try asking this question over in the 'Clutch,Transmission, Differential, Axle and Transfer Case' forum here at FTE. Way more 'tranny heads' down there.
Good luck.
Good luck.
Originally Posted by RocketScience
train460,
Good luck.
Good luck.
will do thanks
Michael
Originally Posted by Max1775
I'm no expert on trannys, but it sound like a sensor or programming malfunction. Is the trans throwing any codes while it acts up?
Max
Max
here is the codes that come up on the superchip. forgot the book so here is the #
P 1247
P 0783
P 0781
P 0732
Later
Michael
0783** 3-4 shift malfunction Circuit failure, faulty solenoid, faulty clutch, PCM
0781** 1-2 shift malfunction Circuit failure, faulty solenoid, faulty clutch, PCM
I'm not sure about the other two codes, but i got these off of http://pages.prodigy.net/stevebaz/_i...az/index3.html
Hope it helps
Hope it helps
Inside the transmission, there is a solenoid pack that controls the shifts etc. It is located on the bottom of the transmission, and can be accessed by removing the pan.
Two torques head screws and a very tight connector that you can't see to the front edge of the pack towards the front of the transmission. It plugs straight up into the transmission. Like the filter does. If these solenoids get dirty; they can cause all sorts of crazy actions. Before you have it replaced though......check the wiring and connections going to the transmission on the outside first. Disconnect and reconnect them. They may have a bad connection. The stealer has a diagnostic to check the transmission. If he tells you that it is the tranny, I've seen this solenoid pack up on Ebay. Get one shipped to you.....or just buy one. Then, you can see how it is made. And see just where to gently pry to get that connector to let go for the removal of the old one. Your transmission, by the way is a 4R100 for reference.
