Exhaust
Old Jan 25, 2005 | 02:16 PM
Need4speed_gsxr's Avatar
Need4speed_gsxr
Smile Exhaust
What is the best exhaust for the 6.0
Old Jan 25, 2005 | 02:26 PM
F-250 diesel's Avatar
F-250 diesel
all depends on how loud you want it, alot of people have the HOG exhaust, but its pretty loud, i heard that MBRP, Magnaflow and Banks all have good exhausts as well. but its all up to your preferences. i heard that most people go with a cat back instead or a turbo back because of the turbo that the 6.0 uses, but you only get about 75% of the power with the cat back instead of the turbo back, but it wont make a big difference
Old Jan 25, 2005 | 02:32 PM
nosdog2's Avatar
nosdog2
To each his own. That is a tuff question to answere since everyones taste is different and they will think there sounds the best. I have the Magnaflow turbo back without the cat and enjoy it. It is a louder than stock, has insane turbo wistle and has no bad sound when normal cruising. Looks damn good to.
Old Jan 25, 2005 | 02:59 PM
Need4speed_gsxr
Is it loud in the cab on cruising speeds? Is there any others you would recommend
Old Jan 25, 2005 | 03:03 PM
Need4speed_gsxr
I do not want it much louder in the cab. though i love the sound of exhaust. i go on a lot of long trips. How loud is the hog.
Old Jan 25, 2005 | 06:58 PM
F-250 diesel
i heard the HOG is the lodest out of all of them and the banks is the most quiet until you put your foot into it....but thats what i heard. nosdog2, isnt it that if you take the cat out and get caught youll get hit with a rediculous fine by the feds??? i heard of people taking out the muffler, will this do anything
Old Jan 25, 2005 | 07:07 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
ANY of the ones MotorHaven sells
Old Jan 26, 2005 | 10:10 PM
levi'sford's Avatar
levi'sford
I had a flo pro put on a few weeks ago. It is was just the muffler, tail pipe, and tip. 4" pipe with a 5" tip. Not much different from stock at all. I am going to go cat back with 4" this spring. The guy who did it for me has done a few gas engines for me and I loved them. Mine has a cat which is stock 3". He said that is where the restricition is and anything you do before the cat isn't going to do much. I wouldn't mind a little more noise. I like the turbo whine. How can I make this louder? Looks really good from outside. Levi
Old Jan 27, 2005 | 08:32 AM
SBV45's Avatar
SBV45
Keep in mind these engines need exhaust back pressure. If the PCM doesn't read sufficient back pressure, the vanes in the turbo won't go wide open. Could be the cause of the insane whistle. Did you read the post on the shortage of replacement turbos. Is there a cause and effect?
Old Jan 27, 2005 | 02:27 PM
Springer's Avatar
Springer
Where is the back pressure sensor? I've never heard of an engine needing back pressure.
Old Jan 27, 2005 | 02:44 PM
SBV45's Avatar
SBV45
Look here in the 6.0L Bible.
http://dan.prxy.org/Truck/6L_bible_h.../Page_058.html
The sensor is located on the driver side front of the engine. The sensor has a tube that goes down to the driver side exhaust manifold.
From the service manual: Exhaust Pressure Sensor
The Exhaust Pressure (EP) sensor is a variable capacitor sensor that is supplied a 5-volt reference signal by the PCM and returns a linear analog voltage signal that indicates pressure. The EP sensor measures the pressure in the LH exhaust manifold.
An open or short in the EP sensor wiring will result in a low out of range voltage at the PCM.
Old Jan 27, 2005 | 03:01 PM
Springer's Avatar
Springer
Thanks for the link! Lots of good info there. I'd like to see what the input for EP does to the VGT output though. I couldn't find anything that describes the control algorithims. My guess would be that lower back pressure would cause the turbo guide vanes to open faster since the turbo can spool up faster with less back preasure.
Old Jan 27, 2005 | 03:05 PM
SBV45's Avatar
SBV45
On the contrary. When the PCM senses low back pressure, it closes vanes to direct flow on to the turbine wheels. As back pressure build up, it opens the vanes and lets the turbo act like a big engine turbo. So If it doesn't sense as much back pressure as it is programmed, the vanes don't open all the way. It can cause turbo surging or overboost.
Old Jan 27, 2005 | 03:13 PM
Springer's Avatar
Springer
Yes of course, I should have thought that out some more. The sensor is ahead of the turbo so it is used to ensure the proper exhaust velocity to the turbine blades.
But this does not mean that the exhaust after the turbo needs restriction. The turbo itself will always present some restriction to flow. Even if there is zero pressure on the outlet of the turbo there will still be pressure in the manifold.
Old Jan 27, 2005 | 07:57 PM
tn mac's Avatar
tn mac
If thats the case why do you think the EBP IS THERE.
