Coil problems
Old Jan 25, 2005 | 01:48 PM
bumpwhite's Avatar
bumpwhite
Coil problems
During Christmas, I lost two coils simultaneously. It appears to have occurred when I went to two wheel drive from four wheel drive. I thought it may have been coincidental so when I got my truck out of the shop, I put it into four wheel drive then back into two wheel and the truck started to miss and about 30 minutes later the check engine light came on. Taking it back to the shop, one coil was bad on the same cylinder as was previously replaced. The repair work was not done at a Ford dealership.
Is it possible switching from four wheel drive back to two wheel drive could cause a high voltage current to the coil? I can't believe two coils would go at the same time unless it is related to some other problem. By the way, I have kept the truck in two wheel drive since replacing the last coil and it is running fine.
Thanks!
websurfer
19
Feb 21, 2024 06:19 PM
Grinder Man
Oct 10, 2014 09:35 AM
PA F250
17
Aug 28, 2013 06:35 AM
Tugly
17
Sep 26, 2011 10:04 AM
Rosson03
Feb 26, 2011 03:32 PM
