Sponsored by: Auxito
4.2 V-6 Hard cold start
Old Jan 25, 2005 | 09:18 AM
hisservant777's Avatar
hisservant777
Hi,
I work in a municipal garage and we have two 1997 F-150s with the 4.2 V-6,
These trucks will not hardly start when left out in the cold. No DTC"s are present, They sound like they are trying to start and will run very rough and stall, Then the one truck will start up and run fine after this episode of stalling, The other one sat outside and we had to push it in to get it to start after 3 days sitting in warm garage, We unfortunately do not have much experience with the newer electronic engine controls, Working in municipal garage limits exposure to these problems, Any suggestions would be appreciated.
Thanks
Old Jan 25, 2005 | 11:35 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
How many miles on the trucks? How many miles on the spark plugs? Or maybe I should ask how many hours of idling if they are municipal trucks. Have the fuel filters been replaced?
Something that's quite common is a dirty IAC (Idle Air Control). It's a cylinder shaped piece with one electrical connector and it bolted to the top of the intake manifold. Try cleaning that with some spray type carb cleaner like Carb-Medic or some throttle body cleaner.
Old Jan 26, 2005 | 07:29 AM
cantrma's Avatar
cantrma
If it's the IAC, somewhat likely, next time you start a cranky one, just crack the throttle a 1/4" or so. If it is the IAC, it should then start right up, but you may have to keep it cracked to keep it running. If they always fire right up with the throttle cracked and don't at idle, it's probably the IAC.
dclinton
May 28, 2021 03:54 AM
GreenMM
43
Apr 21, 2016 09:15 AM
red2002FX4
General Automotive Discussion
Feb 23, 2015 01:50 PM
bebyb
Apr 7, 2014 07:18 PM
Jusitinj608
General Diesel Discussion
Feb 11, 2014 08:03 AM
