Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Help! - Ice dam...
Old Jan 26, 2005 | 07:22 PM
Crash687's Avatar
Crash687
Originally Posted by Ian F
Anyone have any suggestions for melting ice build-up on the edge of a roof?
To melt an ice damn, put calcium cloride in the ends of old nylons(just don't use your wifes good ones) and lay on/ around gutters. Also remove the lower elbows off your down spouts, that way ice will not form in them plugging down spouts.
Old Jan 26, 2005 | 08:11 PM
CTford's Avatar
CTford
Originally Posted by Howdy
Over the office area here's this roof from a one room school house, intact. Instead of tearing it down when they built the new school, they just left it there. I now know from personal expirence that if you keep your roof dry, out of sunlight and at a controlled temperture, it'll last well over 100 years and never leak or have ice problems.
A. How are you going to do this on a roof
B. If you do do this, than what's the point of having a roof? That's exately what roof's are supposed to do!
Sorry, but I just had to say it!
Old Jan 26, 2005 | 08:21 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
gutter heat tape laid on the ice will cut channels to ease the pressure.
Old Jan 29, 2005 | 11:51 AM
99f350sd's Avatar
99f350sd
Salt or hot water from a hose and warm weather...good luck
Old Jan 29, 2005 | 01:12 PM
SSCX2's Avatar
SSCX2
Thats what I was going to say.
Funny most poeple dont know the drain on the hot water heater hooks up directly to your garden hose.
Old Jan 29, 2005 | 03:48 PM
CTford's Avatar
CTford
Yes, but will it reach from wherever it is to the roof? and even if it does, is there enough pressure to get it there? You could leave the cold water feed open, and you might have enough pressure, but you will deplete the water heater fast and then have cold water coming out, not to mention all the mineral junk that has built up in the water heater. I know if you're water heater is in the basement, there probably is little chance of the water getting above the first floor, even if you have a hose that can reach.And, you'll have to do it when it will be above freezing for a long time, because that water will just refreeze, and since it was sprayed up, there is an even better chance of it getting under the shingles. Besides, that would take A LOT of water, which is a worry if you have to heat it first and especally if you have a well.
Couldn't you go get an ice pick and break it up that way? You know, get on a ladder, attach a pole to it, and just break the ice?
Anyway, Good Luck!
Old Jan 30, 2005 | 05:50 PM
rick90yj's Avatar
rick90yj
[QUOTE=CTford]
If he has a bathroom on the second floor, I'd hope the hot water would reach that far.[QUOTE]
Anyway, Good Luck!
Bad idea...what usually happens is the shingles get a bunch of holes punched in them. Best idea is to shovel as much of it off as possible, and then use heat tape to melt grooves through the ice and melt it that way.
Insulation is a good preventive, but he's already got ice.
Old Jan 31, 2005 | 01:45 AM
da'Moose's Avatar
da'Moose
Lay salt in the area of the gutter and build the chanels with salt to drain the build up. I have seen people that fill thier gutters with salt in the fall and not worry about it untill the next fall.
Da'Moose
Old Jan 31, 2005 | 06:32 AM
snyiper's Avatar
snyiper
I say use ice melter if it is available...alt are salt for water softner (crystals not pellets) second is fertilizer it will melt the ice and fertilize the grass when it thaws!! Then heat trace it this spring.
Glenn
Old Jan 31, 2005 | 07:26 AM
Ian F's Avatar
Ian F
This is what I did... worked well enough... no leaks.
Old Jan 31, 2005 | 05:45 PM
rick90yj's Avatar
rick90yj
I should also have included the information that located in Minnesota when we'd get ice dams on my dad's old farmhouse, it was usually well below zero outside. The ice isn't quite as cooperative when it's that cold. We used to use a ice chipper..one of those things that looks like a hoe with a straight blade....and he'd bitch when we punched holes in the shingles. Of course, he also bitched when we didn't. We just wanted to get off the roof.
