2005 Ford Expedition 5.4l - Half the coil packs don't work
Are the coils not working, or are you getting a misfire at those cylinders? Misfire can be much more than coil pack. I can't help with the fuse location.
I know it would be really low odds of all 3 going bad, but have you inspected them? Swapped them around the engine with other coils to see what happens? Replaced them with new coils?
Pull them and inspect the spark plug holes for excess moisture. Is there a coolant leak? Did you plow through water recently?
Inspect the wiring harness. Are there squirrels, mice or rats that might have chewed it? Had any mechanical work done recently that might have pinched the harness?
The following users liked this post:
Woof
1999 to 2016 Super Duty
07-25-2023 05:19 PM
1Aauto
1997-2006 Expedition & Navigator
01-20-2011 10:43 AM
sgl
28
06-14-2006 02:08 PM
