Sponsored by: Real Truck
more than one remote
Old Jan 25, 2005 | 01:16 AM
fatherheart3's Avatar
fatherheart3
how do you program more than one remote for a 1999 f-350 dually..
Old Jan 25, 2005 | 04:14 AM
cgl's Avatar
cgl
You can have up to three FOB's and your manual tells you have to teach your truck to learn the remotes.
Old Jan 25, 2005 | 09:55 AM
fatherheart3
i don't have the manuel..How do you teach it?I was told to turn the switch on and off 5 times and i can hear it cycle,but it will only do one remote..thanks
Old Jan 30, 2005 | 10:42 PM
cgl's Avatar
cgl
This is copied from the 1999 Manual...
If you purchase additional transmitters (up to four may be programmed), perform the following procedure:
To reprogram the transmitters yourself, place the key in the ignition and turn from OFF to ON eight times in rapid succession (within 10 seconds) ending in ON. After doors lock/unlock, press any control on all transmitters (up to four). When completed, turn the ignition to OFF. The doors will lock/unlock one last time to confirm completion of program mode. All transmitters must be programmed at the same time.
Reprogramming transmitters
To reprogram all transmitters, place the key in the ignition and turn from OFF to ON eight times in a row (within 10 seconds). After doors lock/unlock, press any control on all transmitters (up to four). When completed, turn the ignition to OFF. All transmitters must be reprogrammed at the same time.
I know it seems like they repeat themselves ...Don't blame me, I just copied it. Good Luck!
Old Jan 30, 2005 | 11:50 PM
fatherheart3
when i turn the key on ,it cycles at five times..i press the remote and nothing happens..do i have to erase the chip? thanks
