I have a 6500 lb travel trailer which I tow with my 2004 F150 SCREW, 5.4L, 3.73 rear end. If I turn off the O/D, I only get about 8.5 mpg, but I get about 12 mpg using O/D. I haven't had any problems with excessive downshifting and I can easily go 70-75 mph on flat surfaces. Does anyone know if it is considered OK to tow this heavy a load in overdrive? Is something likely to break?
IMO as long as you are not going up and down steep inclines/declines causing the truck to keep shifting you are OK to tow in OD. The Service department will tell you not to but a buddy of mine works for Ford and tows his boat in OD all the time!
I've got several Ford trucks in the fleet and none of my guys turn the overdrive off when they tow. In the six years since we changed from GM to Ford we've only replaced one transmission. Some of these trucks have over 200k on them.
I just switched over from the other team. The 1/2 ton 4l60e transmission had a tow-haul mode to boost fluid pressure while towing, primarily needed when in overdrive at lower rpms. Does the F150 5.4l transmission also have a similar low pressure issue that would be the reason for the dealers recommending not to tow in OD?
I'm towing an 8,300 lb 5th wheel, not only weight but wind resistance. On reasonably flat roads with not too much headwind, I tow in OD. Basically, if my tranny starts shifting up and down frequently, I lock out OD.
Another thing I've noticed is that using cruise control improves towing mileage, at least for me.
Remember riding a 10 speed bicycle. Put the chain on the smallest front and biggest rear sprockets and you can climb Everest just not very fast - this is akin to a high number like 4.10. Reverse the chain to the largest front and smallest rear and you can go like heck but have trouble starting and going up hills - this is akin to a low number like 3.55.
