97 Expy transmission failure??????
Old Jan 24, 2005 | 08:50 PM
RxWarrior's Avatar
RxWarrior
Drving down highway at 65 and heard loud band and grinding noise, coasted to side of road to examine. I found no fluid anywhere and engine seemed to run ok, got in and tried to move. found that could get it to advance but very hard shifting from first to second. could not exceed 25/30 mph and engine was turning about 3000 rpm. was able to limp home about 15miles in this condition. At timms had very hard slips and shudders. Need help quick. BTW the vehichle has 213,000 miles.
Dan
Old Jan 25, 2005 | 04:41 AM
High_Horse's Avatar
High_Horse
Is it a 2x4 or 4x4? .....though it does sound like the pump blew out or the torque converter went south or a combo of both.
I just rebuilt mine at 342k, the converter disintegrated and the pump sucked in the filings, other than that the tranny was fine.
Bottom line for you, not good, sounds like the invetible rebuild.....sorry
Old Jan 25, 2005 | 06:03 AM
RxWarrior's Avatar
RxWarrior
HI Horse, you say you rebuilt yours? Did you do it yourself? Or have a shop do it? About how much was it to repair? Did they just fix your existing one or swap out with another unit? It is a 4x4, does that makes a difference as into what may have let go?
Thanks Dan
Old Jan 25, 2005 | 06:49 PM
High_Horse's Avatar
High_Horse
No, I had my tranny mech. do it, it cost $1800, but he had to replace a U joint and put helicoils in the case. I got a 12/12,000 warranty which came in handy, the new torque converter wouldn't lock, so he had to pull it and replace it. I am glad I didn't have to do that, ...I've done my share.
Yes, the 4 wheel version makes a diff. It could be something in your transfer case that let go. The chain, a gear, gear shaft bearing lots of nifty parts to break. Either way, they have to pull both and will check both for you. I highly recommend letting someone else do yours with that transfer case, it weighs a ton and is a bitch to balance and put back up.
Most mechanics can turn your vehicle around in 2-3 days depending on damage.
