very strange squeaking noise
Old Jul 22, 2002 | 08:09 PM
perryphilip's Avatar
perryphilip
alright, my 85 Bronco with the 5.8HO and C6 has started making a very strange squeaking noise lately. It sounds like something is rotating to cause the squeak, but the truck also does it sometimes right when i start it up and when it's idling sitting still. It does it at complete random times, but more frequently when I hit the gas, brakes, or steer suddenly. It sounds like it is coming under me, and not from the engine compartment I've checked all the belts and they are plenty tight, so i am completely stumped about this. any suggestions would be very helpful..
1985 Blue and White Bronco XLT, 351HO 4bbl, C6, NP208 ,9" 3.55 limited slip, Warn Premium Hubs, Quad Front Shocks, Dual Flowmaster 50's, BFG 32x11.5 ATko's
Old Jul 23, 2002 | 02:06 PM
perryphilip
OK, i figured out that it is one of the pulleys.... any idea which one it might be?
Old Jul 23, 2002 | 07:02 PM
bgodkin's Avatar
bgodkin
Do You still have the smog pump on it? A/C or no? I had the tensioner pully sieze on my 1990 F150 and it squealed like a stuck pig. I had a similar problem with that truck though and it turned out to be the power steering pump. I flushed the power steering system and it went away and never returned. That would explain why it does it while turning and under acceleration also. Good luck and hopefully this will help.
Brad Godkin
1986 F350 XLT
CC/SRW 6.9 auto
Old Jul 24, 2002 | 12:18 PM
400m's Avatar
400m
the way I chase noises is to get a piece of heater hose or radiator hose that is about 12" long put it to my ear and use it as a stethascope. This allows you to isolate the sound easily.
400m
Old Jul 24, 2002 | 12:27 PM
perryphilip
Thanks for the tip. I've never tried that one. I actually have a mechanics stethiscope and find it very very useful, but you see, this noise only happens at random times and i can never get it to squeak when i want it too.
Old Jul 25, 2002 | 10:16 AM
HotWhlz85's Avatar
HotWhlz85
