Bronco II Ford Bronco II
302 injectors
Old Jan 24, 2005 | 06:23 PM
admiralturbo's Avatar
admiralturbo
Smile 302 injectors
Hello All,
I'm curious to know if the injectors from an HO 5 liter will swap right into my 2.9 or will i need to machine and change connectors and stuff...
Old Jan 24, 2005 | 06:34 PM
Monty06's Avatar
Monty06
not able to sorry but if you want bigger injectors you can get some 24lbs injectors
from summitracing
Old Jan 24, 2005 | 07:35 PM
Ken00's Avatar
Ken00
I believe they will swap in but I'm not really sure why you want them unless you adding some more oxygen.
Old Jan 24, 2005 | 11:39 PM
admiralturbo
like porting the intake plenum and adding a high flow filter ?
Old Jan 25, 2005 | 12:04 AM
RomerB2's Avatar
RomerB2
Add a supercharger too
Old Jan 25, 2005 | 07:08 PM
Ken00's Avatar
Ken00
Nitrous, turbo/supercharger. The stock injectors should be able to supply enough fuel for those mods.
Old Jan 25, 2005 | 10:51 PM
admiralturbo
what kinds of forced induction can fit on a 2.9? Is there kits or do you need to fab?
Old Jan 26, 2005 | 12:00 AM
Monty06's Avatar
Monty06
no supercharges exist for 2.9L or turbos
you can try to fab something up haven't seen anything successful as of yet.
Old Jan 26, 2005 | 01:46 AM
RomerB2's Avatar
RomerB2
There is a supercharger made, but clearance problems with the hood occur. I read about it somewhere, don't remember where right now, but it's made for a different car, but bolts right up on the 2.9L.
