? 4 matt03expy
Old Jan 24, 2005 | 05:27 PM
damien67's Avatar
damien67
? 4 matt03expy
Hello matt, hopefully you can shead some light on my situation. I too am in socal and own an 03 expy with faded body cladding. I took it to cerritos ford and they gave me the run around up as high as the general manager! I talked to ford and they said they will not replace them and the matter is closed! I did see some tsb numbers for the fading cladding but they were both different. I also saw that the original cladding was not uv protected and they have since fixed that on the new models, if you can point me in the right direction I would be very thankful,so will my wife, she had a screaming fit while on to some idiot at ford! thanks , Damien.
Old Jan 25, 2005 | 02:54 PM
damien67's Avatar
damien67
need some help
Is there anyone who has FSB numbers for fading body cladding on 03 xlt expy's? thanks!
Old Jan 25, 2005 | 04:25 PM
TDN's Avatar
TDN
Google works wonders
Damien,
Here are the two threads I found with references to the fading body cladding panels.
-Tom
https://www.ford-trucks.com/forums/s...d.php?t=278250
https://www.ford-trucks.com/forums/s...d.php?t=282514
Old Jan 26, 2005 | 08:51 AM
Matt03Expy's Avatar
Matt03Expy
I responded in your other post.
I am sure you will find a dealer to fix this for you unless the vehicle is not under warranty, or some other unforeseen reason.
Old Feb 18, 2005 | 04:41 PM
dmhuff92127's Avatar
dmhuff92127
Thanks everbody. I was looking to get mine painted until I saw this post. New claddings on the way.
