Key Switch Problem
The key switch when turned to the start position will not
spring back to the run position. You have to manually turn it
back to the run position. You cannot feel any positive stops
between off, run, and start position. Also you can do all of this
without having the key in the ignition.
I searched other topics about this and got a general feeling what
it could be. I know I will need the key tumbler assembly because
the the switch works without the key.
Will I also need the ignition switch that is in the steering column?
I have never tore into the steering column before and the Chilton
Manual I have is not very detailed.
I would greatly appreciate any help you could give me in this matter.
Thanks,
Rodney
How to remove the lock cylinder. (this is how I did it on my 81 I am pretty sure your truck is the same)
If you look behind the steering wheel you will see 2 screws (1 on each handle).
You remove thoes screws, and take off the horn pad, make sure not to just pull it off becouse the horn will still be wired in and you will have to diconnect the wires.
After the horn pad is off you will see a big nut, remove the nut. On each side of the nut you will see 2 threaded holes, install a puller and take off the steering wheel.
I suggest you make sure the wheels are in the straight forward position, or if you like the positioning of the wheel the way it is just mark it, and the shaft.
When the steering wheel is removed you will see the casing of the ignition, and near the end there will be a small button. Put the ignition in the run/on position, and push the button with a paperclip, drill bit, or I used an old hanger. With the button pushed, pull the lock cylinder straight out.
To install:
Put lock cylinder in run (if you can't find it, it is the only position the button can get pushed). Push the button, and slide the lock cylinder into the column. Rock the key a little to set the button in place.
The rest is the opposite of removal. When putting the steering wheel on you can position it any way you like, I like to put mine facing alittle to the right so i can grab the left handle and let my arm rest on the window while crusing. check your book for the torque on the big nut and you are prity much set.
If you need more detail just ask, I don't know how much you know so I did not know how much detail to go into.
Good luck!
A test would be to remove the ignition switch and see if the lock cylinder turns with minimal drag, iif it does, then it is the ignitionswitch. If it feels like it is dragging, then it would be the tumbler, but it may just need a little lube, rather than replaced. Don't use any lube that will gum up, as you will be right back into it, use a dry lube like graphite.
Thanks for the information about removing the tumbler. My Chilton book says nothing about removing the steering wheel. It just says that there is a hole in the casting you put a pin in and release the tumbler.
As for the ignition switch the book says to release the steering column so I guess that it is just retained by a couple of bolts and it will swing down after removal of the bolts.
Ya'll have saved me a great amout of time on this. I would have probably eventually figured it out, but it sure is better going in knowing what to do.
Have a great day and God bless,
Rodney
