no spark!
Old Jul 29, 2002 | 09:07 AM
billybob1's Avatar
billybob1
no spark!
Hey guys...
I have an 86 f-150....302...2wd
It will crank, but not fire up. I did a spark test and did not see any while cranking. Where should I start? The vehicle ran fine since I bought it 3 months ago. It also seems like the battery (new) seems to be running down quickly..starter problem too?
Thanks for any help
Old Jul 29, 2002 | 10:51 AM
Mil1ion's Avatar
Mil1ion
no spark!
Test the ignition modulator or the spark ? inside the distributor cap.
If you don't know how take it to a parts place and they can test it.
I hate when I forget a name of something.
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Jul 29, 2002 | 07:34 PM
mshumack's Avatar
mshumack
no spark!
Check for voltage at the coil when cranking. Then use an Ohm meter to check for an open in the coil (do this with wires disconnected - no power). If you do not own a muti-meter than you should not mess with it.
Old Jul 30, 2002 | 05:03 AM
billybob1's Avatar
billybob1
no spark!
[updated:LAST EDITED ON 30-Jul-02 AT 06:04 AM (EST)]I also plugged the wire from coil to spark tester,according to haynes manual test procedure...and got no spark, does this isolate problem to coil? Excuse my ignorance..
Old Jul 30, 2002 | 06:19 AM
mshumack's Avatar
mshumack
no spark!
I'm not sure what you meant when you said "you plugged the coil wire to the spark tester". When you tested for coil voltage did you get 12 volts (while cranking)? You can pull the small wire off the starter soleniod so the engine doesn't actually crank then have someone hold the key in the start position. If you have 12 volts then the ignition switch and wiring to the coil is okay. Next easiest thing is to test the coil itself. Use an Ohm meter and take a reading across the two small wire terminals (you must remove all wires from coil to get correct reading) you should get from 0.3 to 1.0 Ohm, then measure from one of the small terminals to the high voltage connector (where coil wire attaches) you should get around 8000 to 11500 Ohms. If these tests pass then you coil is okay.
Did you pass these tests?
Old Jul 30, 2002 | 08:38 AM
billybob1's Avatar
billybob1
no spark!
[updated:LAST EDITED ON 30-Jul-02 AT 09:38 AM (EST)]Coil did not pass test....will replace...
Should I test control module while i'm at it?...
Old Jul 30, 2002 | 12:24 PM
HotWhlz85's Avatar
HotWhlz85
no spark!
