Offroad & 4x4
360 swap
Old Jan 24, 2005 | 12:04 AM
82f1504x4's Avatar
82f1504x4
360 swap
well you probably remeber a few weeks ago i was asking about putting a 360 from a 72 f250 into my 82 f150. i didn't take any of your advice on it since it was all not to do it. the swap was very easy i just had to lift the motor up about an inch to clear the pan. i took it out wheeling over the wwekend and it was great. the motor runs excellent and has plenty of power for my truck compared to the 300 inline 6 that it replaced. ill get some pictures up so you can take a look
justin
Old Jan 24, 2005 | 06:37 PM
highboy1975's Avatar
highboy1975
well, im glad it went easy for you. for something thats free i guess you did ok, just not the route i would have taken. one question......if you know what you wanna do, why bother asking us what you should do?
Old Jan 24, 2005 | 10:05 PM
fishmanndotcom's Avatar
fishmanndotcom
that's kind of what i was thinking but o well!
-cutts-
Old Jan 24, 2005 | 10:21 PM
82f1504x4's Avatar
82f1504x4
well i was hoping for some helpful advice, when i was first asking about it. just like every other question asked here, but i didn't really get much. i do understand all the advice that was given and all but it was definatly not as hard as it was made out to be
justin
Old Jan 24, 2005 | 11:04 PM
Momudder720's Avatar
Momudder720
You know 82, you might want to document what all you did to shoehorn that beast in, since I'm sure that someone around here has an old 427 side-oiler (since they share the same engine mount placement) just waitin to go into their 80's truck.
Good for you for going against the grain. Nuthin beats free, even if it does take a little, shall we say, ingenuity...
Old Jan 25, 2005 | 12:12 AM
monsterbaby's Avatar
monsterbaby
427 side oiler would be ok but if I could just find a SOHC and put that into my truck then I would be happy, and used the same mounts as the 360 too.
Old Jan 25, 2005 | 12:28 AM
82f1504x4's Avatar
82f1504x4
actually it was very easy to do, i did have to relocate my oil filter because it wouldn't clear the crossmemebr. that was easy enough with a kit. i used the stock rubber mounts that go onto the block of the 360 and built 2 3/4 inch aluminum spacers to put in between there and the crossmemeber since the pan on the 360 was a bit deeper, i raised the tranny and t case to compensate, i used the np435 that was already in the truck. i also had to cut the fender well on the passenger side to get the hedder to fit. i did allof this with only hand tools and a die grinder. not to brag or any thing but im only 17 ill be 18 next month but im not sure of many 17 year olds that are doing stuff like this. im going to get some pics up in the next few days
justin
Old Jan 25, 2005 | 06:52 AM
bremen242's Avatar
bremen242
justin
cool- glad that it all fit for you. I don't know of anybody, except you, that did the swap. That is why we didn't have any info to offer you. Now we do, thanx to you.
did you have to cut a hole in the crossmember, or did it bolt into the stock holes with the spacer?
Old Jan 25, 2005 | 11:35 AM
MBDiagMan's Avatar
MBDiagMan
Since you raised the engine at the engine mounts, did you raise the transfer case also? If not, then you probably do not have transmission output shaft and pinion angles that agree. Don't expect long u-joint life.
Good luck,
Doc
Old Jan 25, 2005 | 01:25 PM
fishmanndotcom
check this out from his last post.... it has some really cool info in it!
-cutts-
