well im glad everyone has like how my 52F2 is going, right now im currently waiting for the new parts that ive ordered, and once there all here im going to be putting her back togather. i put togather a list of what needs to be done and have found out that it help a who lot in focusing on one task at a time, also divide it up into sections... here it is.
THE list
Drivetrain:
-Rewire
-Fuel cell install
-Run fuel lines
-Install trans cross member
-Wire gauges, tach, and reducers
-Install motor mounts and cross member
-Thermo housing, and thermostat
-Valve covers
-Anti freeze
-Trick shift
-Oil
-Driveshaft
-Ignition
-Shifter hookup
-Throttle linkage
Brakes:
-Mount power brakes
-Run lines
-Run stainless lines
-Replace all brakes and drums
Front suspension:
-Install dropped front axle
-Add leafs
-Fix steering
Rear suspension:
-Install new rear axle
-Install 4-link
-Install coilovers
Exterior:
-Sandblast frame and paint
-Repair fenders
-Grip tape sidesteps
-Replace side windows
-Bolt down bed
-Replace sidestakes
-Build 2nd stake fence
-Patch holes
-Touch up paint
-Install side mirrors
