Headers Question.
Old Jan 23, 2005 | 10:29 PM
MemOrex's Avatar
MemOrex
Headers Question.
I been thinking of getting some headers, but if I do, will they fit with the stock Y-Pipe? I really don't want to get a whole new exhaust, I just want to add headers.
Old Jan 24, 2005 | 05:16 PM
95 F150's Avatar
95 F150
My Ford racing truck shorties bolted right up to my factory y-pipe with no issues and they are made of stainless steel so they should last a long time
Old Jan 24, 2005 | 10:07 PM
MemOrex's Avatar
MemOrex
Whats the difference between shorty headers and long-tube headers? Thanks for info
Old Jan 25, 2005 | 05:27 AM
moose94's Avatar
moose94
The overall length. If you compare long tubes are just that. Long. Shortie headers bolt up some what good to the y-pipe. My hedman's went on alright.
Old Feb 2, 2005 | 09:14 AM
Motoshrump's Avatar
Motoshrump
The long tube header has better scavenging characteristics which helps pull the exhaust gases from the combustion chamber and they tend to have a better balanced flow rates from one cylinder to the next compared to the shorty headers. Hope this helps..
How much of a difference did the Ford Motorsports shorties make? I have been contemplating what to buy and i keep coming back to them I just didnt have any feedback on what they "actually do"
Old Feb 2, 2005 | 04:27 PM
95 F150's Avatar
95 F150
The Ford motorsport shorties made a difference you can feel, escpecially in the mid to upper rpm range. I removed them once for a day or so and could immediately feel a decresae in power so they definately help out.
Old Feb 2, 2005 | 08:52 PM
Motoshrump's Avatar
Motoshrump
Did you reset the ECU computer after installing the headers and do you have a freed up intake arrangement to complement the exhaust?
Old Feb 3, 2005 | 01:16 AM
95 F150's Avatar
95 F150
Yes, I reset the ECU after putting the headers on just to start it off with a clean slate after the install. As far as air intake I'm running a K&N drop in filter with a cut airbox, a BBK 56mm twin throttle body and an Edlebrock EFI truck intake manifold. This combined with the shorty headers and exhaust make for a good running combo
Old Feb 6, 2005 | 07:23 PM
Motoshrump's Avatar
Motoshrump
How is the bottom end performance? Besides the headers what are you running for pipes?
Old Feb 6, 2005 | 10:23 PM
95 F150's Avatar
95 F150
The bottom end performance is fine with no loss of low end torque. For pipes after the shorty headers I'm running dual 2 1/4" pipe to Catco high flow cats followed by an H-pipe with 30" glasspacks after that with 3" chrome rolled tips 45'd out behind the rear wheels, sounds and performs great.
