Upfitter switches
Upfitter switches
Does anybody know if they can be dealer installed or if i can order them and install myself?
The truck i am looking at has everything i wanted BUT the switches
Thanks
Thanks
I don't have the part numbers so if someone doesn't post them do a search.
Welcom to FTE
Yes they can be retro fit by user on 05 Superduty only. Two pieces one is a control box and wires that you mount directluy above the insides of the main passenger glove box. The switches and another wire that plug into the back of the Main Fuse box for the power to and from them. The hardest part is mounting the controll box and I suggest getting the dealer to let you look in a truck with the switches. Open the glove box by pushing in the two stops and letting the door swing free to the floor. Get a flash light and look straight up to see how Ford mounted it.... every thing else is very obvious. You will not get any instructions just the two parts for less that $100.
Welcom to FTE
