door window removal
Old Jan 23, 2005 | 08:36 PM
CoachRobb's Avatar
CoachRobb
door window removal
how is the easiest way to remove the window in the door. mine are bad and have new one to replace them.
Old Jan 23, 2005 | 08:53 PM
teds74ford's Avatar
teds74ford
You need to take the door panel off, and slide the window off the crank. I had to take out the vent window bolts to move it around, and then the window came out. Still, it is a little tricky. Good luck.
Old Jan 25, 2005 | 04:56 PM
plowpusher's Avatar
plowpusher
remove the window crank,inside door handle, two screws in the door pull use a trim tool to pop the door panel off ,in the front part of the door above the wing vent are 2 or 3 phillips head screws remove all straight down from the wing pillar is a bolt 7/16 head I believe revoe it now the wing window can be removed it takes some wiggling and twisting but it will come out with the window about half way down you can wiggle it off the window regulator and pull it out off the door put the new window on the regulator put the wing back in lining it to the window and track start the screws crankth the window up tighten the screws
