Sponsored by: Real Truck
Integrated Brake controll
Old Jan 23, 2005 | 06:29 PM
Caterpillar Man's Avatar
Caterpillar Man
Does anyone know if the Integrated trailer brake controll is standard on all super duty, and comercial super duty trucks?
Old Jan 23, 2005 | 06:40 PM
Delawhere?'s Avatar
Delawhere?
The brake controller is an option that can be purchased alone or with the upfitter switches.
Old Jan 23, 2005 | 08:47 PM
SMiller's Avatar
SMiller
The brake controler is not standerd on any Super Duty, but it can be ordered on any Super Duty. From what I have seen all the trucks at the dealers have had them, but then again it seems like all the trucks on the lots are loaded anyways.
Old Jan 23, 2005 | 09:19 PM
Antacus's Avatar
Antacus
I have seen it on *most* trucks in the dealer lots. There have been 3-4 trucks that did not have them.
Old Jan 23, 2005 | 10:40 PM
JWK0721's Avatar
JWK0721
Will This Brake Controller Work On A 2000 Ex?
Old Jan 24, 2005 | 09:09 AM
Delawhere?'s Avatar
Delawhere?
IMO, I don't think it will work in your application as this brake controller is designed to integrate with the 05's braking system, including the ABS controls. You would do just as well going with an aftermarket brake control, and it would be cheaper and more readily available through a local RV supplier.
Old Jan 24, 2005 | 08:21 PM
turn8's Avatar
turn8
Masterbrake makes an add-on ABS system, friend has one. You have to connect to the ABS line.
http://www.masterbrake.com/
good luck
