pcv valve location.
Old Jan 23, 2005 | 06:10 PM
BroncoRoadKill's Avatar
BroncoRoadKill
pcv valve location.
I was wondering if anyone knew where the pcv valve is on a 92 ranger with a 93 2.3L four banger and mazda 5spd 2wd.
Old Jan 23, 2005 | 06:35 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Look on the drivers side of the engine block. Down low under the intake manifold, there is a black rectangular box called an oil separator box. On top of the box is a hose that contains the pcv. The hose routes beyond the pcv up through the intake runners to the area around the throttle body.
Old Jan 23, 2005 | 07:17 PM
BroncoRoadKill
what does the oil seperator look like and what is the use of it, i usually mess with 20 or more year old trucks have never seen an oil seperator.
Old Jan 23, 2005 | 08:44 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
As I recall, it is about 2"x4"x2" in size. Black in color. Top and bottom are stamped sheet metal pieces. It allows a place for oil in the crankcase to separate itself from other vapors in the crankcase, so that oil does not go up to the pcv.
Old Mar 4, 2005 | 08:07 AM
JEG's Avatar
JEG
dual plug motor
were would the pcv valve for a 1989 ranger 2.3 be located this is a dual plug motor with fuel injection
Old Mar 4, 2005 | 08:12 PM
Ken00's Avatar
Ken00
I would guess it's in the same location, same engine and not that many years apart.
Old Mar 5, 2005 | 05:28 AM
JEG's Avatar
JEG
Thumbs up 1989 2.3 dual plug motor pcv valve
Found the pcv valve on my ranger......it was between the fire wall and the intake.....
