Dual Exhaust???
I have had 5 different exhaust configs on the truck and this on seems to be the best. Good low end torque very responsive on the highway speeds but the best part it is the only exhaust the has lowered my egt by 225 deg while towing. No mileage change. What smog canister , never saw and you can't prove it
Originally Posted by Diesel Daddy
I posted about this last year. I got alot of negative feedback regarding using dual exhaust on my 97 PSD. Basically, it was said, that the flow rate would be higher with a single 4" pipe than two 2.5" dual pipes! It all made sense though. I had alot of techical posts on that thread. I'll try to locate it.
A single 4-inch pipe is (3.1416) x (2 in.) x (2 in.) = 12.6 square inches
2 2.5-inch pipes is (3.1416) x (1.25 in.) x (1.25 in.) x 2[ pipes} = 9.82 square inches.
In other words, all else being equal, a single 4-inch pipe has 28% more cross-sectional area than two 2.5-inch pipes. In order to exceed the cross-sectional area of one 4-inch pipe, you would need duals of almost 3-inch diameter - and that still doesn't mean that size duals would flow as well as a single 4-incher.
In short, if you are going to use two 4-inch tailpipes, no problem. If you use two 2.5 inch tailpipes, you will see an increase in backpressure, and probably an increase in EGT and decrease in performance. Probably.
Last edited by arninetyes; Jan 24, 2005 at 03:18 PM. Reason: odd little smileys in it...
-Robb
You are correct, robb. Please note the "probably". That was put there because of the extreme variables in setup and performance between different trucks.
Just wanted to give a reasonable reason for the difference in flow between the two exhaust types.
i thought that backpressure didn't matter with diesels ??? Also is it possible to by this 1 4" to 2 4" Y pipe online or do I have to have it custom made??
It doesent matter if it is a 4" or 5" midpipe, I did 5" because it gives it a lower tone to the exhaust sound, you can find premade splitters at any place that carries diesel truck exhaust components.
I was just thinking, when I do my duals, they will go over the rear axle, but dump at an angle facing down on each side behind the rear tires. I don't know if I would go as big as 4" a side or not. Sounds like the performance of the 2.5" or 3" duals might be best for a slightly modded truck. I don't want to be breathing all those diesel fumes while I'm hooking or unhooking my trailers!
I have three answers possibly - 14 gage aluminized ( it will all depends on your environment what tape of tubing) , did it myself (I own a shop), behind the wheels at a 45 deg angle any questions?
-Robb
The larger pipe will create a resonance inside and inturn will give it a deeper tone. You shound hear one of these trucks with a 6" tailpipe on it. If you don't want to go to 4" or 5" pipe a 3 1/2 dp with a 3 1/2 midpipe split into two 3" tail pipes works great on these trucks that are slightly modded, we have done a few of these and the guys like them.
edub32- we are a drive in shop only
