Sponsored by: Real Truck
Removing front fender liners
Old Jan 23, 2005 | 04:51 PM
Waltdog's Avatar
Waltdog
of American machinists
Arrow Removing front fender liners
I started installing the EGR flares i bought when I noticed a fair amount of dirt/mud built up between the bottom inside of the fender and the plastic liner. Are the liners easy to get out? I would like to take them out to clean them and also add a few clips for the flare to screw to. Has anyone removed these and if so how hard are they to get out? thanks for any help guys!
Old Jan 23, 2005 | 06:27 PM
boxcar1974's Avatar
boxcar1974
They are very easy to get out.....just make sure you dont lose and of those chips.....the problem is theare ment to go in and not come out.....I put headers on my V10 in the summer and removed them.......they are way harder to take out than to put back in........there a a few 7/32 screws and a few plastic clips. Go for it.....just wear lether gloves because the plastic has a sharp and and it wants to pinch your fingers along the fender......seeing it is January....make sure they are warm so they will bend and flex easily........and dont be gentle with them......tung and pull and push and smack......and you can get them out.
austinopa's Avatar
austinopa
A few screws,and some pop fastners. I think that I had to take two bolts loose on the left side. About 15min. work.
Old Jan 23, 2005 | 06:30 PM
boxcar1974's Avatar
boxcar1974
One more thing....there are things bolted to them also.....drivers side is ABS computer and another thing......passanger side has a few also....fuses and such......but they are easy to remove and replace.
