abs not working?
Old Jan 23, 2005 | 11:47 AM
vancouverpower's Avatar
vancouverpower
abs not working?
This is my first rig with abs. At least I think it has abs. It has the idiot light when the key is first turned on. But If I slam the brakes on when it's wet outside the (right?) rear will lock up until the truck comes to a stop. I was told these trucks only have the abs in the rear. I have checked all the fuses under the dash, not under the hood yet. So My question is, how do I know if this truck has abs? If it does shouldn't the pedal pulse if I lock up the brakes?
Old Jan 23, 2005 | 12:02 PM
Kwikkordead's Avatar
Kwikkordead
You have disc or drum brakes in the rear?
My 91 used to do that with drums and a fully working (rear only) ABS due to an out of round drum.
Old Jan 23, 2005 | 12:10 PM
vancouverpower
It is a 99' super duty f250 4x4 with disc in the rear.
Btw do you see a line at the bottom of my post that says what kind of rig I have? I saw it in the preview but not the post.
Old Jan 26, 2005 | 04:29 PM
jman92612's Avatar
jman92612
Let me know what you find out, my truck also does the same thing. Wet road and there she slides on the right rear tire. 89 F350 4x4 460 C6 I have drums on the back and for the time being they are "pro-lock" brakes. I like the out of round drum suggestion.
Old Jan 26, 2005 | 05:19 PM
mjwhip2's Avatar
mjwhip2
You'll only get the signature on the bottom of posts if you are a supporter. Otherwise, if you hold your cursor over the word "signature" in the upper right of each post a little popup window will appear with the sig in it.
Mike
