Nyloc Nuts
Old Jan 24, 2005 | 05:55 AM
boilerbots's Avatar
boilerbots
I find Nylock style are too expensive and difficult to deal with. Another problem is that the bolt has to be long enough to protrude all the way through the nylon or it won't help.
Instead I always use Loctite. I keep all the various strengths handy but prefer the blue (removable strength). It is especially important to use loctite or a nyloc nut when assembling Aluminum pieces because the large amount of thermal expansion. I assume the same problem would apply to wood (moisture not thermal expansion as much).
Old Jan 24, 2005 | 06:03 AM
fatfenders's Avatar
fatfenders
Albuq
Yes, I use the external star washers sometimes too, but I think the split washers are probably the best solution. I've had a couple beds on my truck. I installed gentle the first time. Then come back a while later and snug them just a bit.
I can't think of a perfect solution) I can see possible nylock removal issues down the road on a real trucks bed strip. And nylocks are certainly not immune to wood expansion-contraction either. If the wood shrinks, you'll have a nut that is tight to the bolt, but the strip won't be as tight as if you had used a split lock washer.
I'd just keep an eye on them for awhile after install. Most of us have much bigger issues than this one.
Old Jan 24, 2005 | 07:33 AM
Madathlon's Avatar
Madathlon
here a old Marine trick.. Spring loading the bolts.. it be from top to bottem.. washer spring washer Nyloc nut.. and it would hold the same pressure at all times..
Old Jan 24, 2005 | 11:41 AM
Jag Red 54's Avatar
Jag Red 54
I've never had a problem with nylok nuts, but I have had SS bolts gaul. They need a little lube on the threads to prevent the threads from mushing together. I'll bet that is what caused the problems, not the little ring of nylon in the nut. Good luck, John
SVTDriver97
'80-'86 HOWTO's
Jun 23, 2016 08:18 PM
SuperTruckUSA
Vendor Specials, Discounts, Product Announcements & Group Buys
Feb 18, 2016 02:25 PM
Paul250
Jun 7, 2015 07:10 AM
neverdoneanoilchange
Oct 18, 2013 07:13 PM
steveclv
27
May 30, 2012 03:05 PM
