Wiper/headlight knobs
Old Jan 22, 2005 | 02:37 PM
!977f250's Avatar
!977f250
Wiper/headlight *****
Is there a trick to getting the ***** back onto the shafts? The opening inside the **** seems to big to grab anything.
Old Jan 22, 2005 | 06:27 PM
Steina's Avatar
Steina
CO River Rat
If the shafts are D-shaped, then usually the ***** have a plastic/nylon insert or set screws to hold them tight.
Steve
Old Jan 23, 2005 | 02:06 PM
stephenw's Avatar
stephenw
The **** on the light switch shaft is not intended to be removed; rather you should be pulling out the entire shaft w/**** while depressing a tab on the top of the actual light switch body.
The Wiper switch **** should have a springy steel catch to hold the **** onto its shaft, similar to the apparatus on a storm door pneumatic closer shaft that holds it open. For removal, you use a U-shaped wire, or similar, to pull on that catch at the same time you apply pressure to the **** itself. The wire hook goes into a molded notch on the ****. It's a little awkward for the first time you try it.
Old Jan 23, 2005 | 06:03 PM
!977f250's Avatar
!977f250
Stephen,
Just got the ***** on. That did the trick. Thanks a lot!!
