wiper problem
Old Aug 3, 2002 | 09:15 AM
Dylan J's Avatar
Dylan J
wiper problem
hey, guys this is my first post so bear with me i have a 1984 f-150 and im having some wiper problems!out of stupidity i forgot and left my delay on in the winter of course the next morn there was ice on the windshield and anyway to make a long story short the delay altogether quit and wipers would work then slow down to a drag so i replaced the switch same problem then i got a wiper motor for free from a friend off of i think a 78 model anyway now they work but will not shut off its like they are on low on delay/off/low and high works fine if anyone has any ideas or possibly knows what the problem is it would be greatly appreciated. thanks in advance!
DYLAN
Old Aug 3, 2002 | 09:20 AM
Jimbare's Avatar
Jimbare
all alone in the world
wiper problem
if you follow the wires from your wiper switch. you will find the delay controler. it just plugs inline with the wiper switch. remove it from your system and see if that cures your problem. if it does just replace it. when you unplug the delay control on eachend, the wires will plug directly on to the wiper switch.
Old Aug 3, 2002 | 08:51 PM
brokebronco's Avatar
brokebronco
wiper problem
I had the same problem. the thing you have to watch out for is the switches are different for intermittent and regular wipers. If you junk the delay bowich is very expensive) and run normal wipers you should change the switch. There is a thermal circuit breaker in the delay box but is in the switch in regular wipers. It only ran about $25 at for for the regular switch.(beats an electrical fire)
BROKEBRONCO
Old Aug 4, 2002 | 12:40 PM
Dylan J's Avatar
Dylan J
wiper problem
>BROKEBRONCO
thanks guys now i have some where to start before i honestly didnt have a clue thanks so much
dylan
Old Aug 11, 2002 | 04:38 PM
Dylan J's Avatar
Dylan J
wiper problem
hey guys still have problem i removed delay box and i had reg switch laying around so i put it in and still the wipers stay on any ideas anyone
thanks Dylan J
Old Aug 11, 2002 | 05:19 PM
Jimbare's Avatar
Jimbare
wiper problem
Powerstroke-7.3
Dec 22, 2012 04:56 PM
srteach
6.4L Power Stroke Diesel
Oct 17, 2012 07:47 PM
turnkyle
Dec 31, 2011 11:53 AM
84-250
Electrical Systems/Wiring
Aug 7, 2005 03:54 PM
D Ray
Aug 19, 2002 12:50 PM
