headlights and ammeter
Old Jul 29, 2002 | 02:19 PM
kemp67d's Avatar
kemp67d
Post headlights and ammeter
[updated:LAST EDITED ON 29-Jul-02 AT 03:22 PM (EST)]My names David ,I have a 1979 f250, everything under the hood is new .A friend and I built a 351 windsor with alot of goodies. It has been in the truck ayear now, and now out of the blue the headlights are pulsating and even with them off my ammeter needle constantly jumps to the right. Alt, voltage regulator were all new. Can anybody tell me what to do? Thanks
Old Jul 29, 2002 | 02:24 PM
HotWhlz85's Avatar
HotWhlz85
[updated:LAST EDITED ON 29-Jul-02 AT 03:25 PM (EST)]I'm no electrical expert, but I'd start by checking the obvious....connections. Since you rebuilt this motor(and you obviously had the engine out and then back in the truck) make sure your ground is good. Check all wiring to make sure connections are tight then proceed from there.
Ron
Edit: And welcome to FTE!!!
Old Jul 29, 2002 | 02:25 PM
dpoelstra's Avatar
dpoelstra
my '86 is doing the exact same thing. It is internally regulated, and I am assuming that it is the voltage regulator. Am I right?
Old Jul 29, 2002 | 03:11 PM
kemp67d's Avatar
kemp67d
Thanks for the quick response, I checked all grounds and they seem to be good and tight. could it be in the alt?
Old Jul 29, 2002 | 04:51 PM
HotWhlz85's Avatar
HotWhlz85
The easy way to find out is take it to AutoZone/Advance Auto, etc. I know the two I mentioned here will check your alternator for free.
Ron
Old Aug 12, 2002 | 09:41 PM
kemp67d's Avatar
kemp67d
Well its been awhile since I posted my problem and I have gone to an electrical shop they swore it was the voltage regulater, so I replaced it still no luck, took the alternater and had it checked they said it was perfect. I have grounds from hood to cab from frame to fenderwell from block to firewall and neg battery terminal to block.
Old Aug 13, 2002 | 12:09 AM
82F100SWB's Avatar
82F100SWB
Try changing the light switch, they have a circut breaker built in, and, they do tend to get weak after it's been tripped once or twice and cause the lights to flash on and off.
Evan
86 F250 HD XLT Lariat Explorer 4x4:
460/T19/BW 13450 3.55 geared Full Floater 10.25 and Dana 50 TTB
1982 F100 SWB
300 HD: NP 435/2.75 geared 9"
78 F150, 351M/C6, soon to be repowered with a 400
Old Aug 13, 2002 | 10:41 AM
kemp67d's Avatar
kemp67d
well the headlights are not going off but they kinda just pulsate . when the moter is reved a little they pulsate faster at the same time my ammeter needle is jumping with the pulsating lights.?
Old Aug 13, 2002 | 10:55 AM
kemp67d's Avatar
kemp67d
Just thought I,d add that I put a new dimmer switch in a year ago. But I know thing s can still go bad.
Old Aug 13, 2002 | 03:27 PM
dpoelstra's Avatar
dpoelstra
In my 86 i replaced the headlight switch and it did not help. Any other suggestions?
Old Aug 13, 2002 | 08:18 PM
Franklin2's Avatar
Franklin2
