Sponsored by: Real Truck
door pins
Old Jan 21, 2005 | 11:20 AM
Redmonster5's Avatar
Redmonster5
door pins
Sorry if this has been asked before, however I did a search and could not find anything. Anyway, it seems as if my driver's side door pin is not working, after I close the door the interior light stays on, however I have an extended cab and see only a switch on the extend cab door, is this the switch that works the interior light when opened? If not can someone give me some advise as to where the switch might be located? I have on 01 SD F250 extended cab, thank you all.
Old Jan 21, 2005 | 11:45 AM
Redmonster5
Nervermind, I found some post, thanks guys.
