starting problem 93 e-350
Old Jan 21, 2005 | 08:49 AM
lost_in_space's Avatar
lost_in_space
I figured even though this is a cube van it uses the same 6 cyl motor the trucks of this age use.
I bought this from a friend who had a used motor put in it. When he got it back it started & ran fine but after a couple days no starting it without starting fluid, even hot you can turn it off after a hour drive & immediatly it wont restart without a squirt of starting fluid.
I threw the following parts at it to no avail.
* Set of Plugs
* distr cap & rotor
* air filter
* fuel filter (inline on frame)
* fuel pressure regulator
* pcv valve
I tested the fuel pressure with a newly purchased gauge & the running fuel pressure from the schreder valve is about 48-50 & turned off after a run is about 49-50.
The one big thing I noticed is while pulling plug wires while running one at a time to see if the engine would change, it sure did each time except no change for cyl #2 (2nd closest to the front). I guess its running on 5 cylinders but it dosnt miss that bad to me but im not used to the thing. Is this for sure a dead cylinder or maybe the fuel injector for that one isnt giving jack for fuel? could this be enough to start with only starting fluid? What gets me is after immediate shut down it wont restart. I understand that I should do a compression test on that cylinder but I havnt found my tester yet.
lost_in_space
Jun 6, 2021 10:10 AM
golley
4 Cylinder Engines
15
Oct 2, 2013 09:53 AM
TallPaul
Aerostar
23
Sep 27, 2013 01:56 PM
brushwolf
General Diesel Discussion
Apr 1, 2013 06:36 PM
hivoltj
Apr 13, 2011 02:49 PM
