touchy brakes........
Old Jan 21, 2005 | 03:33 AM
kaintuck's Avatar
kaintuck
This is my first post...i have a 95' f150 w/5spd trans. the brakes were put on new.....my mechnic is a good fellow, and i don't want to make him mad..BUT! the brakes just require a "bird touch" and they stand you on your head! WHAT CAN I DO?
another question: why won't the heater get hot? it blows nice warm air....it will freeze you to death driving in weather below 40 degrees!
Old Jan 21, 2005 | 03:50 AM
TexasGuy001's Avatar
TexasGuy001
I'm not sure about your brakes, but it sounds like the calipers might need to be replaced. As for the heater, I would suspect that the thermostat is stuck open. That would not allow the truck to warm up all the way. Its also possible that the heater door is not going all the way to the hot air side. Thats just my thoughts.
Old Jan 21, 2005 | 04:39 AM
kaintuck's Avatar
kaintuck
brakes.....
i had new pads put on.....but the calibers are the problem you think?
and i have a new thermostat.......i will ask about the door thing!
thanks!
Old Jan 21, 2005 | 05:33 PM
TexasGuy001
Its very possible thatt the calipers are the problem with your brakes. It could also be the master cylinder. If you have a new thermostat then thats about all I can think of for the heater problem.
Old Jan 21, 2005 | 06:30 PM
polarbear's Avatar
polarbear
Just went through this- had brakes, rotors, and calipers replace 5K miles ago, and had to have it done again. We also noticed the brakes were real "touchy" after the last brake job, but not this one.
diagnosis: the "pin" the caliper slides on was dirty, causing it not to release properly. Previous tech also didn't replace the inner release spring-clip on the passenger side. Viola- touchy brakes (and crappy gas mileage). After new pads and those pins cleaned, drives like a new truck again.
Old Jan 21, 2005 | 06:32 PM
polarbear's Avatar
polarbear
re: Heat. Does it have factory A/C? Loose/leaking vacuum line would cause the valve @ the heater core not to open completely.
Old Jan 21, 2005 | 11:19 PM
superhooperduty's Avatar
superhooperduty
touchy brakes
just wondering, would a 91 f150 4x4 also have a inner release spring clip? and what does this spring clip do? thanks
Old Jan 21, 2005 | 11:48 PM
polarbear's Avatar
polarbear
I'm sure it does- it holds the release spring in place
Old Jan 22, 2005 | 08:35 PM
superhooperduty
touchy brakes
thanks, but mine doesn't seem to have any springs of any sort on them, we are talking about disc brakes right? sorry for yet another dumb question
Old Jan 23, 2005 | 12:03 AM
polarbear's Avatar
polarbear
I'll try that one more time- doesn't hold spring in place, it's a spring clip on the back side of the caliper.
Old Jan 23, 2005 | 08:52 PM
superhooperduty
touchy brakes
isn't that the anti rattle spring,(funny shape and clips onto the inboard brake pad)?
Old Jan 23, 2005 | 09:10 PM
polarbear's Avatar
polarbear
I do believe you're correct.
Old Jan 23, 2005 | 11:43 PM
Vinford's Avatar
Vinford
diagnosis: the "pin" the caliper slides on was dirty, causing it not to release properlyCould you describe this "pin"?
Im having trouble with touchy brakes also in my 88.
Old Jan 24, 2005 | 01:43 AM
polarbear's Avatar
polarbear
the two "slides" that hold the caliper to the hub. Last go-around, they replaced the calipers without cleaning the slides.
