Driveshaft alignment info?
Old Jan 20, 2005 | 11:35 PM
RangerFloyd's Avatar
RangerFloyd
Hey everyone. I recently replaced my 3 u-joints and the carrier bearing on my 93' Ranger, 4x4, supercab. I am now getting a slight vibration at around 45-65 mph. I forgot to mark the position of the two driveshafts before i took it off to do the u-joints and im sure that may be my problem. Does anyone know if i can and where i can get info on the correct position?...and suggestions would be great....or if you have any other ideas on where this vibration could be coming from. There seems to be no abnormal play in the driveshaft. I have had my truck looked over and everything visually appears fine. Thankyou.
Old Jan 21, 2005 | 08:16 AM
3Lstroker's Avatar
3Lstroker
I did the same thing with mine. As long as you sight down the drive shaft and all of the u-joints are in alignment, you should be ok. You should be able to see the "rust mark" on the pinion flange where the drive shaft hooks up at the rearend. It is the same on two sides. Line up your u-joints, and flange, if you get a vibration, turn the pinion flange 1/2 turn and test drive for vibration. That is the best you can do. If it is bad enough, I have had some driveline guys tell me that all u-joints are not equal and they recommend balancing after a u-joint change. Good luck.....
Old Jan 21, 2005 | 02:11 PM
RangerFloyd
thanks a lot......ill try that
Old Jan 21, 2005 | 03:23 PM
ol yeller's Avatar
ol yeller
I suggest balancing, had too many driveshaft woes.
kidzstang
1997 - 2003 F150
Oct 23, 2016 11:23 PM
camsamjam
Jan 21, 2007 10:40 AM
HMA-169
1978 - 1996 Big Bronco
22
Dec 17, 2004 01:34 PM
MustangGT221
Offroad & 4x4
15
Feb 22, 2004 07:22 AM
