Frame swap
Old Jan 20, 2005 | 11:22 PM
badgermike68's Avatar
badgermike68
Frame swap
Hi folks,
I normally browse the 61-66 forum, but I need some help from you guys.
I am currently restoring a '64 longbox and have decided to swap it onto a newer frame for the modern upgrades. The ticket is apparently to use a 73-79 4x4 frame (the closest match to a '64 where the cab mounts)....sorry if this is a dumb question but....are the front end components from a 2 wheel drive a direct bolt-on to a 4x4 frame?
I have a '75 XLT with a great running gear, the cab mounts and body from my '64 and a '65 parts truck. The 4x2 frame WILL work for the swap but it is alot of work to match up the body/mounts etc.(the frame is wider). Should I keep looking for a 4x4 frame or am I wasting time if I can't put the 4x2 front end on?
Thanks for any help you can give me.
Mike.
Old Jan 20, 2005 | 11:31 PM
buzzbait65's Avatar
buzzbait65
to answer your first question, no, 2 and 4 wheel drive frames are completely different in the front.
as far as the second question, i cant figure out what you have and what you are doing , can you be more specific, ie; (75 2x4 for the running gear)(64 for the cab)(will it work)
Old Jan 21, 2005 | 08:34 PM
badgermike68
Sorry for the sketchy details...the simple question was if the 2wheel drive front end will fit a 4x4 frame...thanks for the answer.
I have a '64 Custom Cab longbox that I am restoring...I want to put it on a newer frame so I can have disc brakes, power steering and I.F.S. I have been told that I should be looking for a 4x4 frame as it is the closest in dimensions to my '64....I don't want to build a 4x4....I know I can make the '75 frame mate up to my '64 body, I was hoping that using the 4x4 frame would simplify things a little.
If you have any ideas that I have not heard I would love to hear them!
Thanks agian.
Mike.
Old Jan 22, 2005 | 08:03 AM
buzzbait65's Avatar
buzzbait65
try a suspension upgrade search in the 61-66 forum
good luck
Old Jan 22, 2005 | 09:20 PM
plowpusher's Avatar
plowpusher
you must be talking about the f250 frame because it is the old narrow width like your truck just for grins a 72 and ealier 4x2 frame is the narrow stile maybe looking that direction wnd getting after market I beams for the disc brakes or seeing if late model i beams would fit
