Sponsored by: Auxito
Hard to shift transfer case
Old Jan 20, 2005 | 07:39 PM
deerhunter 1's Avatar
deerhunter 1
I have a 2000 F-150 4x4 automatic . Lately it has been getting harder and harder to pull back the transfer case lever to engage the 4x4. any suggestions ? It has not been damaged , and the four wheel drive works fine when I can get it engaged.
Old Jan 20, 2005 | 10:20 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
I've seen these transfer case shift levers seize up. There are plastic bushings in the lever where it pivots. You can remove the shifter, pull it apart, clean and lube it.
Old Jan 21, 2005 | 07:45 AM
L.TONY F350's Avatar
L.TONY F350
see my following post
Old Jan 21, 2005 | 11:07 PM
deerhunter 1
Thanks for your suggestion . I'll give it a try .
deerhunter 1
