96 expl elect problem
Old Jan 20, 2005 | 03:23 PM
rost495's Avatar
rost495
HI folks
posted yesterday on this. A long story but I have not been able to look at battery connectiions but wife gave more info today when it happened the 2nd time.
While driving the radio goes off. Voltage gauge goes to max voltage, battery icon comes on along with ABS light. Then all goes back to normal except the ABS light stays on.
Runs fine the whole time and has no problems starting vehicle.
Apologize for crazy post but in a bit of a rush today
Thanks, Jeff
Old Jan 21, 2005 | 08:09 AM
rost495's Avatar
rost495
Maybe at least an answer as to why the battery icon comes on, why the volts go to magrounding short???) and why the ABS comes on and stays on? ABS is anti lock brake right??
Jeff
Old Jan 21, 2005 | 10:16 AM
fefarms's Avatar
fefarms
Check the battery cables, all the grounds, and all the connections at the alternator. This could be either an intermittant open or intermiittant short. An open could cause the alternator to run wide open, a short would cause momentary low voltage followed by runaway alternator output trying to recover.
The ABS light comes on because the ABS control computer does not appreciate what is happening to its power supply. Think of it the same way as Windows giving you a "blue screen" when power to your house momentarily dips. The computer's brains get scrambled. Had the power failed completely, the computer would have rebooted, but in this case it just sits there with scrambled brains.
In the truck, the momentary sag/surge causes inconsistency checks built into the ABS to trip, and the ABS computer gives up as a safety measure. It does not want to try to control the brakes in any way if there is doubt about its ability to do so. You have to cycle the key to clear this fault.
Old Jan 21, 2005 | 02:27 PM
rost495's Avatar
rost495
thanks, will have time to check cables this weekend and connections to battery and alt. Lets hope.
JEff
